Hi guys, it’s been a bit since my last post but I’m finally back to working on my daughters TJ frame ip rebuild after a couple month hiatus for work and other life happenings. Things are going pretty smoothly at the moment and I just put the body back on the frame after doing the NV3350 to 32rh swap (I hope I’m done anyway lol) and the last thing that I know of that I need to do to complete the swap is change the ECM to one for an automatic, which should be fine considering I have a donor vehicle that I got all the goodies from for the swap to get one off of but I got to thinking last night that I might have a conundrum as the current TJ is a 2000 and the TJ that the automatic came out of is a 98 and it has a distributor which the 2000 doesn’t. I looked through the threads I could find from others that did the swap but I didn’t see anyone with this situation, or at least I don’t remember seeing it and I wanted to see if anyone knew if this is going to be an issue. I don’t have any knowledge of ECMs and how they are programmed etc but I know some of the gurus here will be able to help me out. If I need to find another ECM or get mine worked on now would be the time before I finish getting it all back together and finding out then. Thanks in advance and I can’t wait to get this project finished and post up pics!!
