A question I've pondered many times and since we get to deal with all the models, there is no immediately obvious difference in components except for two that are obvious. First is they updated the radiator from a 2 row to a single larger row which then became the standard even for earlier models and stayed the same through 2006. The other is the switch to a different water pump and changes to the engine block to accept it which happened in 2000. The new pump has a plastic impeller and is very reliable and much more so over the older metal impeller style.
None of that is mentioned in the TSB so that shouldn't have much effect.
What makes the plastic impeller water pump more reliable? I’m not doubting this one bit, I’m just generally curious.
