I've bought some Brown dog stuff in the past...my opinion these days is that it's junk. Mopar is the way to go, once those fall by the wayside I'll probably use M.O.R.E.
The Brown dog bolt torque recommendation is a joke. Snugging up the bolts until the washers stop moving and then slightly loosening the bolt until 1 or both washers move doesn't really make any sense. Essentially the end result is no torque on the bolt, just the nylock holding in it's position.
What's more crap is that when you finally remove the BDs, usually the bushings are loose and fall right out. I've got a MML set that I spent $160 on that I can't find a buyer for.
