I have driven my jeep tj without a thermostat for 4 months and i opened my valve cover for leaky gasket and saw very bad sludge inside. Tried out engine flush of liqi moly but that didn’t work out.
what should I do?
I use sea foam motor treatment in the oil and gas around a week or two before I change the oil. I find that it works with the sludge for the most part and the first time I used it seemed to worked Pretty well. I would recommend putting a Stant Thermostat In so your engine can run at its normal operating temperature.
