Sorry, I should clarify here. The replacement motor mounts are Mopar. The Savvy skid does away with the stock transmission mount and uses a Savvy provided mount. The replacement mount uses two rubber bushings for vibration control. I knew there would be an increase, based on the design. However, the previous Savvy skid I installed was on a manual transmission and the vibrations were not as pronounced as they are with the automatic. It has been awhile since I did that install, so perhaps I'm just imagining it to be worse.
