Pls help, I was getting a really bad ticking so u took off the valve cover and checked up on the rocker arms to find a few loose. I replaced the bolts and put it all back exept the valve cover. I go to test start it and starts after cranking for a while. It backfires. From the intake and will run but super badly and sounds like tracter. And only with gas. PLS HELP!!!!
