I've seen a few threads (including the great write up that Chris did) that had guys installing extended brake lines, and their rigs had varying lift heights. Is there a certain amount of lift where extended lines are a must? I'm at 3" in the front, and 2" in the rear, and wheel with the front disconnected. I hadn't thought to check how tight the lines are when flexing, but I will next time I'm out.
Also, most just seem to extend the front, and leave the rear stock. I'm guessing the rears must have enough slack in them?
