Fan clutch
Jakejeep2005
Mountain Home Arkansas
i’m looking for a replacement fan clutch for my 05 wrangler 4.0. i need to know what kind of fan clutch a wrangler comes with from the factory, is it a thermal or a non thermal clutch. and if anyone has any links to good brands (preferably OEM) then please link it. thank yall!
The Hayden @CodaMan linked to is a great option. It will make a little more noise than you are used to for a few months and then in my experience it will settle down and you'll forget you changed it.
Reactions: CodaMan
I just put the Hayden on my 2005 last week as we were low speed wheeling with the AC on in 95 degree heat and my OBD scanner showed 235. Changed the clutch, now only seeing 205-210 in same conditions. Yes, much louder than what I took off, but it obviously wasn't working 100%.
On another note it is very confusing as depending on where you look, it lists the 2771 as both Standard and Reverse Rotation (including in Haydens own online catalog), but it is the correct one.
Reactions: pagrey
