The only thing I've needed to do since I've owned mine is replace the rear oil seal, which isn't too bad. The other is the splash back issue while filling the tank. Had to install a flutter valve (instead of replacing the tank). The issue is caused by deterioration in the tank mechanism that prevents the splash back due to ethanol fuel use. There is a thread on it here in the forum if that issue comes up.
