6”Nope! you ordered the wrong drive shaft. To use the one you ordered you would need to install an SYE kit and then the length you ordered may not be correct.
What size lift to you have?
Why did you need to replace it to begin with?
Thank you! They are awesome folks!No SYE is needed, that's a Rubicon tcase. You need to get back in touch with Tom Wood's and tell them you accidentally ordered a flange style but needed a u-joint style CV joint.
They are indeed. I added a comment above that they can likely just swap the part forward of the slip-joint on the shaft to get you going.Thank you! They are awesome folks!
Im on a 6” lift but I’m getting ready to take the entire suspension off. I’ll see what I have to work with! Thank you so much for the info!They are indeed. I added a comment above that they can likely just swap the part forward of the slip-joint on the shaft to get you going.
And if you're having big vibrations, is the rear pinion angle set properly? The rear axle's pinion shaft should be pointing up directly in line with the driveshaft.
Like this....
Damn you caught my mistake before I was able to edit it. You're too quick sometimesNo SYE is needed, that's a Rubicon tcase. You need to get back in touch with Tom Wood's and tell them you accidentally ordered a flange style but needed a u-joint style CV joint. They should be able to swap the part from the slip-joint forward to get you going.
I had the pleasure of wandering around a 4x4 show with Tom Wood years ago, he is just the nicest guy to chat with. He makes everyone feel like they're his long-lost old friend. You don't meet many people as nice as Tom is.TW Driveshafts has OUTSTANDING customer service.
Just give Tom a call and I am sure he will take care of the problem.
One of our group had damaged one of the TW driveshafts due to his aggressive use of the skinny pedal and Tom personally brought a new driveshaft to the event "Good Public Relations and Customer Service".
A Jeep Technician friend know Tom Woods and while in Moab several years ago I met Tom and our group went to dinner at the Moab Brewery.
It's not a CV yoke output, it's a u-joint output yoke. That type of yoke doesn't know the difference between a u-joint and a u-joint that's part of a CV. Mine has that u-joint yoke-style output shaft and it came that way from the factory.Is that a Rubicon case with the flange replaced to a yoke? I'm not aware of any Rubicon years coming with a CV yoke output.
I thought you still had the NV241OR in that thing, no? If so, it came with a flange adapter on the harmonic balancer that has been removed and replaced with a yoke.It's not a CV yoke output, it's a u-joint output yoke. That type of yoke doesn't know the difference between a u-joint and a u-joint that's part of a CV. Mine has that u-joint yoke-style output shaft and it came that way from the factory.
There absolutely is a difference between a CV yoke and a non CV yoke. The 241 also did not come with a CV yoke from the factory.It's not a CV yoke output, it's a u-joint output yoke. That type of yoke doesn't know the difference between a u-joint and a u-joint that's part of a CV. Mine has that u-joint yoke-style output shaft and it came that way from the factory.
That’s not stock. Factory Rubicons had a flange.It's not a CV yoke output, it's a u-joint output yoke. That type of yoke doesn't know the difference between a u-joint and a u-joint that's part of a CV. Mine has that u-joint yoke-style output shaft and it came that way from the factory.
I don't know what Gerald did before I bought it. I do know I have seen a 241 with a yoke on it, and I happened to see the yoke for sale on eBay a day or two ago as well. http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=302899123690I thought you still had the NV241OR in that thing, no? If so, it came with a flange adapter on the harmonic balancer that has been removed and replaced with a yoke.
That’s the stock front output yoke.I don't know what Gerald did before I bought it. I do know I have seen a 241 with a yoke on it, and I happened to see the yoke for sale on eBay a day or two ago as well. http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=302899123690
