1998 TJ Wrangler with 98K actual miles. Went to drive the jeep and battery was dead. Jump started with power pack and drove around to recharge. Parked in driveway and waited to put it away. Had to jump it again to put away. That is when I found the flashers were blinking without the hazard switch turned on. I have replaced with new battery and flashers are still working. I have cycled the hazard switch repeatedly. Battery connections are clean and tight. I checked fuse 9 and flasher in the Power Disctibution Center and the flasher fuse behind glove box. Both had continunity. Flasher relay at the base of steering column was replaced. Did not resolve the issue. I am looking for what to check/replace next.
Thanks,
Thanks,
