Hey y'all!
This is my first post on this forum! I bought a 2000 Wrangler Sahara with a 4.0 manual transmission and 63k miles on it a few weeks ago and I'm looking to replace all the fluids but I'm having trouble finding which kinds to get. I did some research but it's really overwhelming for me right now. Any help would be greatly appreciated!
Here's what I have so far:
Coolant - Doing a coolant flush and putting in Valvoline Zerex G-05
Already did the oil
Front and rear differential
I have a Trac-Lok in the rear diff. What 80W-90 gear oil would be best? I know I need something with a limited slip additive because of the rear diff.
Transfer case
I'm pretty sure I have the NV3550.
https://www.amazon.com/dp/B000TWDVM8/?tag=wranglerorg-20
Manual transmission fluid
https://shop.advanceautoparts.com/p/pennzoil-synchromesh-manual-transmission-fluid-1-quart-3501/7070062-p?product_channel=local&store=8533&adtype=pla&product_channel=local&store_code=8533&gclid=Cj0KCQiAuefvBRDXARIsAFEOQ9HiGtVJ_bTi_D2DyD6qea8GDVq7cijZWk95VvZ079AAkBVISy4CIPAaAratEALw_wcB&gclsrc=aw.ds
Power steering fluid
Any suggestions on power steering fluid? I've read some posts about using ATF+4 for power steering for Chrysler cars made after 98'.
Brake fluid
https://www.amazon.com/dp/B004AHDCB8/?tag=wranglerorg-20
Clutch fluid
Should I just use the same fluid that use for the brake fluid?
Any suggestions on what I've provided would be amazing!
Already did the oil
Transfer case
Brake fluid
Clutch fluid
