@Goatman and @someguysjeep . Thanks for your posts. But which Eastwood product are we talking about now? The internal frame coating product? I'm just surprised, because it is clearly pitched as something that can be applied to existing rust. From their site:i talked with an Eastwood rep at the store. the recommendation was application to clean metals. not that it won't cover and convert some rust, but if it doesn't do a total job it just gonna seal junk in.
they also suggested when i mentioned it had previously been FF'd, if any oil based product was applied b4 a product like this it needs to be totally cleaned b4 application or it won't adhere.
and FF after eastwoods will soften it, FF is designed to penetrate.
This special aerosol spray is both a rust prevention and rust destroyer formula rolled into one. The conical nozzle reaches directly into the frame and sprays in a wide pattern radial pattern to fully cover the surface while reaching deep into the sub-frame. Phenolic resin encapsulates the rust hiding inside the chassis so it doesn't rust its way through and destroy the frame from the inside out. Once this is completed, zinc phosphate seals the frame against additional rust.
I think that's what @Superjay5 was getting at, above. I mean, I can understand the worry of sealing moisture inside, but if you're sure the inside of your frame is dry, and that it has some existing rust, isn't that exactly what the internal frame coating product is intended for?
