I have a Yukon Zip in my front Currie Dana 44. It was highly recommended by the vendor/installer, rawkhaus,
http://rwkhaussupply.com/. He said exactly that — it has a better warranty than ARB. Though it is a copy of one of ARB's older designs, which turns off some. They took the old ARB design and supposedly improved it to make it stronger.
I do have the ARB in my rear Currie 60. Obviously not a direct comparison, but I am curious to see if either has problems first. If the ARB breaks first, I might replace it with the Yukon, or vice versa.
Though the thing nice about the Eaton is it's an e-locker, so doesn't need air. A simpler install if you don't already have air. Since mine were both originally ARB with the OEM housings, I already had air running there. If not, probably would've gone with the Eaton.
