I am going to address a frame repair issue on my TJ center section. My frame is no where near as far gone as some that I have seen. Matter a fact I only have an issue with the forward bolt on the passenger side trans support pan. I am still going to consider capping the entire center section on both sides anyway. With most of these caps that you purchase, it is recommended that you remove 2/3 of the existing frame. This seems extreme considering the condition of my frame. I am aware that the bottom portion of the frame removal is required as the existing bolt locations will prevent a tight fitment. Also removal of any damaged frame to prevent spread. Does anyone have any thoughts or knowledge of why i would need to remove anymore frame than needed. Will leaving more than half of the existing frame affect the fitment of the new caps. Thanks
