So a little update:
I went ahead and went with the Pocono Metalcraft front and rear trail arm patches. My center section of the frame is still solid due to my sleeved through-hole skid plate mount modification. I got the driver rear patch welded in with all of the measurements correct and I went on to do the passenger side and found that the lower control arm mount is welded 1/8" higher on the patch than it was on the other side. I reached out to Pocono and they said that this is completely fine and that I wouldn't have any issues at all with 1/8" difference in height from one side to the other, but the measurement from the front control arm mount to rear is extremely critical and I need that measurement to be the same on both sides (57 3/16" in my case). They said that my control arm bushings will make up for that little amount of difference in height. Does this info check out or are they just looking for a way not to send me a new mount?
