Hello,
Backstory:
I bought a 2005 Unlimited LJ a little over a month ago. Mod wise it has a 2.5" OME lift, JKS track bars front and rear, and Rugged Ridge drag link/tie rod. It developed a little shimmy, not death wobble, and I found out 2 of the tie rod ends were bad, so I replaced them( the drag link/pinion were new so I left them). This made it better, but there is still a little movement when driving. The previous owner said he replaced the upper and lower control arm bushings, and they look good. I did the ball joint test, and the uppers have a little movement, so I am planning on replacing them.
Question:
I have a click and it feels like the axle moves if I am backing up and the front tire goes over a rock. When checking bolts today, I had a wrench on the lower control arm bolt where it meets the axle. When I pulled forward on that bolt, I heard the click and the axle rocks slightly. If I look where the tie rod meets the steering knuckle, I can see the steering knuckle moving up and down when I pull on the lower control arm bolt. Is that the ball joints that are allowing that movement of the axle? I know they need to be replaced, but I want to make sure it isn't anything else. It seems like everything else is fairly new.
Any advice would be greatly appreciated, I searched and cold not find anything about the axle rocking forward/back.
Backstory:
Question:
