Yup, ask me how I know.Yes he can. Then he can get on here and ask how to spread the yokes back out to seat the snap rings in the grooves.
If I could find one that fit the 5-760-X joints, that would probably be all I would use. It is the perfect way to remove the caps since it isn't trying to mash the two yoke ears together if the cap binds in the yoke hole.@mrblaine I know you like to beat the ignorance out of u-joints as evidenced by your prior posts, but I would like your honest opinion on this style of u-joint puller. (Not necessarily this particular brand but this style in general) There's a shop close to hear closing it's doors and selling off some tools he has one like this that I could probably get pretty cheap.
I gather I should probably make sure it fits my needs before I spend money on it... Thank you!!If I could find one that fit the 5-760-X joints, that would probably be all I would use. It is the perfect way to remove the caps since it isn't trying to mash the two yoke ears together if the cap binds in the yoke hole.
Maybe, but when you remove a TJ knuckle off of the ball joints, all you do is pull the castle nuts and then smack the little shelf at the top of the knuckle with hammer and knock it off of the ball joint pins. With a shop hammer, I can get them off in anywhere from 1-3 smacks. Generally 1 will do it, stubborn ones take 2. Really stubborn ones take 3. I got a lot of core knuckles back at one point. You can clearly see that lots of folks really needed to set their purses down and just hit that thing. The whole top of the knuckle is peppered with these little tiny dents from a less than large tack hammer. All I can envision is they gave up and went and got their mommies to help.I think I just grew hair in places I didn't have.
Don't be afraid to load it up and then smack the yoke on the pushed out side to keep the bind at bay.That OEMTools u-joint puller is cool, here's a good video on using it...
Would I be correct that the 24539 is the one needed for our TJ joints? 1" to 1.25" cap sizes since the 5-760-X joints have a 1.188 cap. It's only $75 on Amazon.That OEMTools u-joint puller is cool, here's a good video on using it...
I've done my fair share of u-joint replacements, I just wanted Blaine's opinion on that puller. I've used ball joint presses, vices, and the tried and true hammer and socket method. Each method works some better than others but Blaine confirmed my assumption that the puller I asked him about is ultimately the best way to go about it.Do you have a good vice? There is a technique that you can use that does not mess things up and save the the cost of a puller. Those pullers work well just not always worth the expense if you are not using it all the time.
Love those vids. Helps keep me employed when I fix their messed up yokes.
You mean like this?A press or vise makes it way too easy to bend the yoke or ears.
