Front end noise
Brandough
California
While I was wheeling, my jeep started making this noise at least until I got up and over this obstacle. It doesn't make any noise while driving. I drove home okay with no noise. It only made the noise one other time during this trip which was when the jeep started to flex. I have a stock sway bar and normally I disconnect it. During this trip I chose not to. I'm having a hard time replicating this issue. These are the only two videos I have with the noise. Any ideas on what I should check?
  • IMG_3747.mov
    20.1 MB
  • Video_1.mov
    604.4 KB
The going down hill VID almost sounds like bushing in your control arm noise, where as the other VID going uphill and rolling back sounds like possible your fan hitting the shroud.
I see you have the Savvy body lift what about motor mount lift?
When was the last time your greased the upper/lower control arms?
I would look at your fan shroud for any possible signs of fan strikes and look at your condition of your motor mounts.
Interested to hear from others and what you ultimately find is the issue.
