I have sloppy steering and a hard pull to the right. Went in for a Mavis Discount Tire alignment and the mechanic said it wouldn’t even register on the machine…took it down the road to another shop and on the lift the sway bar end link came apart and both were replaced. Now the fix-it list is being tallied. What is the bare minimum to keep me on the road until I can get to it all? (just drove 500 not-fun miles but have more summer trips on the calendar)
I can’t afford everything but I want to address the most important parts that contribute to sloppy steering first. Anything worth “upgrading” around same price as stock? No plans beyond current 31” tires.
Stock everything and likely all original. 2000 4.0L auto 153k miles. Not a DD but needs to be 70mph highway capable.
Is this order right? Here's what I think I need in order of priority. I was quoted $800 for everything but shocks/springs. Budget around $400-500.
- Upper & Lower ball joints
- ZJ tie rod & draglink (same price as TJ OEM)
- Lower control arms
- Upper control arms
- Shocks (definitely toast)
- Steering stabilizer
- Springs
- 31” BFG KO2 tires
- Refreshed brakes all around (pads, rotors, brake lines)
- New sway bar end links (Moog) after the failed alignment
