Front Track Bar Questions
WWII Jeeper
Cody, Wyoming, United States
For my 2006 TJ X, stock, no lift, 1 inch body lift only:
Do I go with an adjustable track bar ?
and if so, what are the advantages with that over the stock type bar ?
Right now I don't have any intentions of going with a lift.
I'll be replacing the steering components with heavy duty Moog, and I've been told by a local shop that I need to replace the front track bar. Going for a second opinion on that, and I figure I'll start here in case it's confirmed.
Thanks
Ray
With no suspension lift, you don't need an adjustable track bar. If the bushings are bad then a new track bar is in order.
Perfect, thanks again. Can't say it enough, what a great site this is, and great people willing to jump in and help-
Ray
Always happy to help! We've got a great bunch of guys and gals here, that's for sure.
Reactions: StG58
You're welcome. If you are going to replace front suspension components, and a tie rod is on the list already, you might want to do the ZJ tie rod conversion while you are in there. It's a beefy upgrade for little additional cost. Plus, it puts all the adjusting bolts on one side, making it very slightly easier to do your own alignments.
X2^^^
Here’s the link to the How To Do ZJ Tie Rod Conversion
https://wranglertjforum.com/threads/zj-tie-rod-conversion.2373/
The cost is around $270 through Amazon for all the parts
Reactions: BigskyTJ and StG58
The Moog setup, all three parts, cost me just shy of $100 off Amazon, with free shipping.
Oh yeah, that’s right, I’m figuring the Drag Link in too, which is like $100, as well as that tie rod end, and a steering stabilizer, so oops, cost would come down to about $100!
Reactions: StG58
