Front Track Bar
CHAWK
Mississippi
Do any of you guys know if a JKS adjustable front track bar for a 1999-2004 grand Cherokee will fit my 2005 Tj? JKS technical Rep said it would but it’s definitely not the same part numbers. I want to hear it from the you guys that I trust🤣🤣 Thanks.
The JKS PN depends upon the amount of lift the vehicle has.
S126: 1-3" lift
S128: TJ requires 2.5" plus suspension lift; ZJ requires 3" plus suspension lift; XJ & MJ require 3" plus suspension lift.
S127 and 129 ONLY fit the WJ with a 1-6" lift.
AFAIK, the WJ front trac bar WILL NOT fit a TJ without modifications.
