I have successfully pulled the wheel bearing assembly off the front of the Dana 30. I'm planning to replace the rotors, calipers, pads, etc.
The only thing that concerns me is that when I pulled the hub assembly the u-joint and inner axle came out with it. I cleaned everything up and am planning to get the hub installed. Is there anything special I need to do with putting that axle rod back in so it lines up safety in the front differential? I noticed when I cleaned it up that the little black plastic thing on the axel doesn't sit flush like it did originally. When I placed it back in to test fit I checked and I can spin the wheel and the other front wheel spins like it is in the gear.
Pic below:
Pic below:
