I have a 2005 Wrangler X, 4.0L inline six with 125K miles. Suddenly the Jeep will start chugging while driving down the road then shuts down.I have replaced both the Cam and Crank shaft position sensors, two O2 sensors, installed new plugs and the coil pack. Neither of which solved the problem. When this happens, I turn off the ignition key and restart the engine it will run again but the problem repeats. Sometimes I can drive it for day or two with no problem, sometimes it occurs repeatedly.
I'm at a loss. Has anyone experienced this issue and how did you fix it?
