Fuel issue with 2006 TJ
KentuckyJeepster
Kentucky
Hello All...
New here... I'm hoping this is the right place to post my question. I have a 2006 Jeep TJ, 2.4L with 6-speed manual, with about 96k miles on it. A little while ago (4-weeks) it developed a miss. Then that developed into a no-crank/no start situation. Testing seemed to indicate the Engine Control Module was inop, so I replaced it. After that it started and ran just fine. I have put about 500 miles on it since the ECM was replaced with no issues. Yesterday I ran a few errands in the Jeep, parked it, came out to run another errand about an hour later... and crank, but no start. Today, after checking some fuses and such, I shot a squirt of starting fluid in the intake... and it fired off (till the starting fluid ran out). So... obviously my issue is fuel related.
Question... in short, where to start. Is there an easy way to test if the fuel pump is getting power (fuse is good (power to both sides with key on), and swapped fuel relay with another relay and no change. The tank has 15+ gallons of fuel in it so dropping the tank is a last resort for me. Some say I should be able to hear if the pump is running, but I have never heard the pump run, even when the jeep was running fine. Also, is the fuel pump controlled in any way by the ECM ? If so, can I test to see if it is supplying power to the pump ? At this point I am leaning (gut instinct) on the ECM... it was a Re manufacture unit from Rileys Auto Parts. If the fuel pump is running, the ECM triggers the injectors, so if its a fuel issue I guess there a good chance its the ECM. But I need to check if the pump has power first I think. Any thoughts ???
Thanks...
Check the condition of the Automatic Shutdown Relay.
This type of relay has been known to have contacts that can stick or the relay prongs may be oxidized.
Thanks Charles...
There was a relay in the engine fuse box marked "ASD"... I assume that is the one you suggested. It appeared to be the same relay as the horn relay so I swapped the ASD relay for the horn relay, as I know the horn works. No change... crank but no start.
The fuel pump comes on for about 2 secs if you turn the key to on and don't crank it. You should be able to hear it. Or have someone listen by the back of the Jeep when you turn it on.
Testing the fuel pressure is a pain since they removed the schrader test point. An adapter has to be inserted between the fuel rail and fuel line to attach a gauge.
Any codes? If it is in fact the ECM(PCM), I would only trust Wrangler Fix for a replacement.
