Hey folks I filled up today and i was at the red line and only put in 10 gals. is it possible that someone put in a new fuel pump and sending unit, and it be the wrong stuff?
Did the previous owner run trails with it? I mashed my factory skid plate up enough to lose a couple of gallons of capacity. The final straw was I pretty much killed my fuel pump running the Busywild here in Washington. I've got a new pump and a good skid plate tied up to the frame now.
Even if you replace the fuel pump and sending unit that may not be the cure.
I recently replaced my fuel pump with a Bosch setup.
My fuel needle now seems to lag behind the actual fuel use some, so i make sure and fill up @ 1/4 empty.
Maybe it's inherent in the design..?
I've read jeep fuel gauges can be a bit wacky
It's still worth it cuz now I tan take turns fast without the engine cutting out ! ... ;-)
