Well FWIW as a career electrician here's my 2 cents. Yes automotive wiring is not exactly the same and I don't claim to be an expert on it but much still applies and current is still current, theory is still theory. If the winch can be fixed so it is only connected to the battery when needed then I don't feel short circuit protection is absolutely needed, as when using it you will be right there "attending' to it, much like the electrical code that allows for certain installations when they are carried out, operated and maintained by qualified persons where those same installations would not be approved for the general public.
Now a permanent installation, either for yourself or especially for someone else, I don't feel comfortable without short circuit protection. Things can go wrong which will be out of your control, and can leave a liability if you did it for someone else. I try and follow ABYC standards when I do automotive wiring which I often have to look up but I have found much of ABYC follows the same basics as the NEC.
There are a number of reasonably priced options, you could install an inline MEGA fuse and MEGA fuseholder, you could go with ANL, or you could go with a marine type circuit breaker. You could even go with a MRBF if you have a way to mount it on your battery terminal.
Marine Rated Battery Fuse (MRBF)
All are available up to 400 amps. I like the circuit breaker as it can also be used as a disconnect. There isn't a lot of mounting options under the hood of a TJ but it is possible to fit a marine circuit breaker, mine is on a home made bracket that I bent up on my Grizzly 6" Bench Vise Brake and it screws on right next to my ECM. (Everyone needs one of these brakes, I have bent up lots of handy stuff with mine, they make them in 4" & 6"). My breaker is for my air compressor but I have come off of it with other things using the convenience of the studs and fused those loads accordingly, you can come off the battery side for this.
You can also go the MEGA or ANL route and get bolt down holders or floating inline holders. I like to go with name brands like Blue Sea or Littelfuse when possible even if it means not going to Amazon, it doesn't cost that much more to get name brand stuff that you can trust. I buy some stuff from Mouser.
In addition, absolutely route the wire out of harms way and cover it with flexible wire conduit. That's my .02 anyway from an electrician's viewpoint, it's easy enough to add protection that I don't see a reason not to. And yes I have seen a conversion van burn from an unfused audio install, it started in the dash when they were driving and by the time they got pulled to the side of the road it was full of smoke and they bailed out and couldn't save the van.
MEGA Fuse
Marine Style circuit breaker mounted to home made custom mount
MEGA Fuse
