Need some advice on my gear pattern. This is a used gearset with unknown mileage that came with this new-to-me Dana 44. I'll be regearing and adding a locker next year so this setup only needs to last ~10k miles.
Option 1:
Pinion: 0.032 + 0.013
Driver Carrier: 0.143in
Passenger Carrier: 0.126in
Backlash 0.011in (out of spec)
Pinion Preload: 20 in*lb
Pinion + Carrier Preload: 30in*lb (with dry setup bearings)
Coast:
Drive:
Option 2:
Pinion: 0.032 + 0.013 (same as option 1)
Driver Carrier: 0.148in (thickest shim I have)
Passenger Carrier: 0.124in (thickest shim I have)
Backlash: 0.0055in
Pinion + Carrier Preload: 40 in*lb CCW and 60 in*lb CW. Much higher than the manual's guideline however I did add 3 thou of preload vs #1 so I'm not too surprised.
Coast:
Drive:
Tomorrow night I'll try option 3 (0.145 and 0.124) as long as the committee agrees that pinion depth is good enough. That combo should get a better amount of carrier preload although backlash is unknown.
Option 1:
Coast:
Drive:
Option 2:
Backlash: 0.0055in
Coast:
Drive:
