Gear swap
97JadeTJ
Hot Springs, AR
The new jeep has a Dana 30 and Dana 35… the build sheet says it came with 3.07’s but it has 33’s on it and I did the math and I’m pretty sure it’s been regeared to 3.55’s… I‘ve Found a set of 4.11’s out of a TJ Dana 30 / 35 on marketplace for $100… here’s the question, if I’m right the carrier break is 3.55 on the Dana 30, and it so happens i have a Dana 30 3.73 carrier out of the old TJ, so that should work… but the build sheet says the new TJ has trac lock in the Dana 35, do I have to worry about carrier break here or will the 4.11’s attach to the Trac loc….
