How to identify axles on a Jeep Wrangler TJ (and what the difference is with each axle)
Chris
Administrator
Staff Member
Florence, AZ
I'm surprised an article like this didn't already exist on the site, especially given the number of people who ask how to identify which axles they have on their Jeep Wrangler TJ.
The goal here is to give future TJ owners and new TJ owners a guide on how to identify which axles they have under their TJ.
FRONT AXLES
Dana 30
  • Front axle used on all TJs except the Rubicon model
  • Stock gear ratio options = 3.07, 3.55, 3.73, 4.10, 4.56
  • Carrier break = 3.55 / 3.73
  • Open carrier - no Trac-Lok limited slip option
  • Ring gear diameter = 7.2"
  • Ring gear bolts = (10) 3/8 x 20 RH
  • Low pinion (short pinion)
  • Pinion shaft diameter = 1.376"
  • Pinion shaft spline count = 26
  • Axle shaft diameter = 1.18"
  • Axle shaft spline count = 27 both inner and outer
  • Axle shaft u-joints = 5-760x / 5-297x
  • WMS-WMS = approximately 60.5"
  • 5 x 4.5" bolt pattern
  • 181mm
Dana 44 (only available on Rubicon models)
  • Standard front axle used on all Rubicon model TJs
  • 4.10 gears
  • Tru-Lok selectable pneumatic locker - open differential when unlocked
  • Ring gear diameter = 8.5"
  • Ring gear bolts = (10) 5/16 x 18
  • Low pinion
  • Axle shaft diameter = 1.31"
  • Axle shaft spline count = 30 inner / 27 outer
  • 194mm
  • Note: The outer axle shafts, unit bearings (hubs), knuckles, and brakes are the same as those found on the TJ Dana 30.
REAR AXLES
Dana 35c
  • Standard rear axle used on all TJs except the Rubicon model
  • Carrier break = 3.31 / 3.55
  • Optional Trac-Lok limited slip differential
  • Ring gear diameter = 7.5625"
  • Ring gear bolts = (8) 3/8 x 24 RH - NOTE: 7/16" x 20 RH used on later model TJs
  • Low pinion
  • Pinion shaft diameter = 1.406"
  • Rubber pressed-in fill plug
  • 194mm
Dana 44
  • Optional rear axle used on 6 cyl models except the Rubicon model
  • Standard on all TJ Unlimited (LJ) models
  • Stock gear ratio options - 3.55 (97 only), 3.73
  • Carrier Break = 3.73 / 3.92
  • Standard Trac-Lok limited slip differential on early model TJs / Optional on later model TJs
  • Ring gear bolts = (10) 3/8 x 24 RH - Note: 7/16" x 20 RH used on later model TJs
  • Low pinion
  • Available for the 1997 and newer 4.0L TJs only after 7/7/96
  • Threaded 3/8" fill plug
  • 216mm
  • Standard rear axle used on all Rubicon model TJs
  • 4.10 gears
  • Tru-Lok selectable pneumatic locker - limited slip differential when unlocked
  • Ring gear bolts = (10) 7/16" x ??
  • Low pinion
  • 216mm
What's the Difference Between the Jeep Wrangler TJ Dana Axles?
Aside from the differential covers, the biggest difference between the axles is the size. The number in the name (Dana 30, Dana 44, etc.) is in reference to the sizes of the axle.
Dana 30: This axle the front axle most commonly used on all non-Rubicon model TJs. There was no other front axle option available for the TJs other than the Dana 30, unless you got the Rubicon model, which has the Dana 44 front axle. The Dana 30 came with either 3.07, 3.55, 3.73, 4.10 or 4.56 gears.
Dana 35: This was the rear axle most commonly used on the TJ non-Rubicon models. The Dana 35 came with either 3.07, 3.55, 3.73, 4.10 or 4.56 gears (the 4.56 gears only came in the late model TJ SE's with automagic transmissions).
Dana 44: This axle was used both front and rear on all Rubicon model TJs (03-06), and was also used as an optional rear axle for 97-06 non-Rubicon model TJs. Finding a non-Rubicon model TJ with a Dana 44 rear axle is not very common, and certainly commands a higher resale value. All Rubicon Dana 44s had 4.10 gears, while non-Rubicon model Dana 44 rear axles had 3.55 (97 only) and 3.73 gears.
Did this section come from a JK site? In the Dana 35 section, it says something about being used in 2007, and the lockers are pneumatic, not electric like is mentioned in the last sentence.
Reactions: H_E_H
Good call, I forgot to re-write that section, which I just did!
Reactions: H_E_H and Mike_H
OK, I’m a newb. I feel ashamed. I’m a retired teacher that was on the top of the food chain in my profession. I’m a Dad that based on all accounts was a good Dad. I’m a husband that’s been married for 33 years to the same woman (how she’s put up with me is a testament to her, not me) and yet I’m apparently Axel illiterate)
So, even thou I’ve studied Chris’ pics, read the specs;I’m still uncertain. What rear axel do I have on my ‘03 TJ? Thank you, y’all are better than I!
Sent from my iPad using Tapatalk
So, even thou I’ve studied Chris’ pics, read the specs;I’m still uncertain. What rear axel do I have on my ‘03 TJ? Thank you, y’all are better than I!View attachment 32115
Lucky you, that’s a Dana 44!
Reactions: JMT
i bought a tj a week ago and i was scrolling through this forum , im new to this whole jeep thing but by reading i think i have a rear dana 44 on my 04 tj sport and wanted to know what are the advantages over the dana 35
Yes, that is a Dana 44. The Dana 44 is stronger than the Dana 35. In addition to that, you'll find much more aftermarket parts and support for the Dana 44 axles as oppose to the Dana 35. With a built Dana 44 you can very safely run up to 35" tires.
Reactions: JMT
Sorry to bring up an old thread but I too am new and just want to make sure I know what I have. To me the front is a 30 and the rear is the 44? Pictures are in that order.
Thank you for all your help!
Yep, that's a Dana 30 front and a Dana 44 rear.
Thank you for the great write-up! I just purchased my first Jeep; 2006 Wrangler X. They look like the Dana 30 front and Dana 35 rear. Can you help a noob out and confirm?
Yes, that's a Dana 30 in the front and a Dana 35 in the rear.
Just a note on the Dana 30 / 35 combo with the 4.56 axle ratio. The 4.56 gears only came in the late model TJ SE's with automagic transmissions. Those axles are probably rarer than Dana 44's. FWIW
Wouldn't it be nice to have 4.56 gears from the factory?
Reactions: Ephry73 and StG58
Dana 35/194MM and Dana 30/186MM on my '99 Sport Automatic TJ.
Using my VIN, I discovered: 3.07 rear axle ratio
Very informative threads, Chris.Thanks for creating and sharing the knowledge.
