For those running Genright fenders, what are you using for side/turn signal lights? I bought a set of Blaine's 3 wire LEDs for the front, but need something on the side.
I changed to headlights that had a turn signal built in.
https://www.amazon.com/dp/B00GNU4944/?tag=wranglerorg-20
I think others have done the JK lights in the grille. I didn't want to modify the stock grille. I'm happy and never think about it.
I think he’s referring to side facing lights, not the forward facing ones.
I bought the GR kit. I wouldn't buy it again. I've replaced the cheap 3/4" ambers with some much better Truck-Lite versions. If I were to do it over, I'd just get four of the Truck-Lite 3/4" ambers.
Get another set from Blaine (and run it as a 2 wire?).
I may end up doing this by installing a second set from Blaine on the inner fender. I'll need both the side markers and turn signals to pass inspection in VA though.
I don’t know if they were with Genright fenders, but someone had post a little while back that they used these for a side marker light I think.
psler Motorcycle LED Handlebar Mount Mini Turn Signal Indicator Lights Lamps Blinker Running Light Brake Clutch Lever Mount Fit for Touring Models 2014-2020 Softail 2016-2017 with Hydraulic Clutch https://www.amazon.com/dp/B0BPM2T338/?tag=wranglerorg-20
I ended up buying the GR kit with the fenders. Then, before installing, I found the MetalCloak dual-use marker/turn signal front light.
So my setup isn't the cheapest but got me what I wanted:
Front:
[URL]https://metalcloak.com/dual-function-led-marker-blinker-light-tj-lj.html[/URL]
From my build:
[URL]https://wranglertjforum.com/th...005-tj-build-thread.69559/page-4#post-1395825[/URL]
Side Marker (I installed GR after seeing @AndyG's use of them and liked the look - I wanted a side turn signal because we have a lot of double-lane roads around here and I want the person next to me to know to get the F&%* out of the way lol):
[URL]https://genright.com/shop-by-v...led-stealth-marker-blinker-light-kit-4-light/[/URL]
From my build:
[URL]https://wranglertjforum.com/th...005-tj-build-thread.69559/page-7#post-1429039[/URL]
This gave me the setup I wanted with markers up front and turn signals on front and side. I think you're use of the BMB at the front and in the wheel well will give you a similar outcome. I actually was thinking of something similar with just using the circular LEDs before I settled on this setup.
The GR fenders don’t really have a place to mount anything directly on the side. The angled front edge with the 3/4” Amber is all I use for a side marker. Something could be mounted underneath on the inner fender, but like @Longwhitejeep said, I’m not sure how Virginia law states the side marker must be mounted, but I counted the 3/4” Amber on the angle as a side marker.
Do turn signals have to wrap around the side of the rig? Mine are just on front. Never had an issue. YMMV.
Yeah I assumed with the angle if the gen right 3/4 round led in the gusset hole, that was side mount enough.
