Generally I hate older ABS systems from the 90's and 2000's. They are too slow and you'll need a half a mile to stop in the snow once the ABS kicks in. I've pulled the fuse in my TJ and feel as though I have better control in slippery conditions than the stock ABS controller can provide.
That said, I have the opportunity to get a set of JL Dana 44 axles from a wrecked JL for really cheap. I've driven in a JL and played around with the ABS and it is light years ahead of the TJ/XJ ABS system. It got me thinking... if I swap in the JL axles could I get the JL ABS system to work in a TJ?
Obviously the TJ ABS controller would have to be swapped out for the JL one but my concern is more the electronic compatibility. I know the TJ ABS module doesn't communicate with the PCM. The only outside world function of the TJ ABS module is a hard-wired warning light on the instrument cluster and it also connects to the OBD2 data link. I don't think the TJ ABS talks to the PCM at all and that is a standalone system all on its own.
Does the JL ABS controller work similarly? Is it a standalone system? It would be pretty cool if I could install it and make it work. Anyone have any idea? Thanks!
