Sri,
I was thinking they had a 1997-2002 version and a 2003 up version? I could be wrong though
I’ve got a set I removed prior to installing a cage. Will need to dig them out of the garage.
They fit both year ranges. I originally had them on my oem late model windshield frame. After a roll I installed an early model windshield frame. The spreader bars at the windshield frame uses the same bolt pattern.
You are correct I remember now.
How do those work with the plastic trim in place?
You have to drill holes in the plastic trim
I can see that now when I zoom in on the top picture. Looks like about 1 1/2” hole saw size. Thank you.
