I used the Red N Tacky grease, thank you forum for the recommendation. A few of the fittings, around the rubber seals leak grease. I made sure not to overfill. SO I am going to replace tie rods, ball joints and corresponding parts.
Does this kit look good, comprehensive and decent quality? https://www.amazon.com/dp/B07BYK8G1L/?tag=wranglerorg-20
Looks decent for $149 but I am willing to spend more for a quality kit if anyone can recommend.
No lift, all factory stock, 31' tires, and steering stops, 2 washers. That the extent of mods to height, the 31's. So I assume any good quality factory type OEM set will work. Thank you in advance for the tips on what brand to get.
