So I have a bad grinding noise when i take off kind of fast, replaced all my ujoint and ball joints sound is still there, only happens on takeoff also have a bad vibration that I think is on the tranfer case , when it's on drive it will vibrate and when on parking will stop. but it won't do it all the time I also check the spider gears and the pinion and ring gear and it's fine. It does have a 4 inch lift and 32 inch tires but looks like driveshaft was not replaced with the lift. Can that be the problem
