I have recently installed xprite LED headlights - which are awesome - - but... the daytime driving light halo is a tad brite. I have both halo's running from the same power source - which is only powered when the engine is running. As to the brightness, I believe I have one of two choices: a) install an inline resistor to reduce the power to both simultaneously or b) install a LED dimmer switch. I have a dimmer - but it requires the power side and the ground to run, so can I run a common ground to the dimmer or do I need to run a closed ground to each headlight. Secondly, I'm not sure what size resistor would be required to dim the halos 25 - 30%. Any insights/advice offered is greatly appreciated.
Guts
Guts
