Recently bought a 1998 TJ Sahara with 163000 miles. Sometimes it is hard to get into first from a stop. It it takes a firm pressure to get it in, 2nd gear is a bit notchy but fine otherwise, 3rd to 5th are as smooth as butter. It's still driveable, but sometimes i worry i won't be able to get it into gear at a red light. I changed the transmission fluid to Redline MT-90 about 100 miles ago and it feels like it got slightly better, but the problem is still there.
Symptoms:
This leads me to believe that the clutch isn't fully disengaging and keeping the the input shaft of the tranny slightly spinning, but i could be wrong.
After reading a lot about this issue, some people say the synchros on the AX-15 are known to go bad. Some people have replaced the slave/master cylinder and the problem goes away. I just ordered the LUK pre-filled master/slave assembly. Hopefully that fixes the problem. Has anyone else had this problem?
Symptoms:
- Seems like it happens after driving a bit and the Jeep warms up.
- If I put it into 1st while rolling at ~2-3 mph, it slides right in without any problem.
- sometimes it grinds into reverse when at a stop
- I can go through all the gears with the engine stopped, no problem
