@TrueTexas sorry I did not notice this before. I have not exactly figured it out. I've just been tolerating it. I find that if I very consciously push the clutch to the floor and then slowly shift and wiggle the shifter a bit it works nearly all the time. The few times it won't I just get really annoyed and get honked at, and it works eventually...
What is the "front seal leak" ... I am aware of engine rear seal but what do you mean by "front seal" - where is it located? I do not see leaking fluid under the vehicle.
Thank you!
The front seal leak is the tranny front seal. It is on the front of the tranny where the bellhousing meets the transmission.
You may be able to do a cursory inspection if you remove the starter and look inside the bellowing. A borescope would be very helpful.
