I absolutely have not proven your point. The driveshaft does not need to be perfectly aligned across. People with ford 8.8’s in TJ’s don’t have vibrations, people without adjustable track bars at all don’t have vibes. Riddle me this, if your driveshaft can handle 15 degrees (or more) downward, why can’t it handle 1 degree side to side?
the DC joint handles 15 degrees downward, but the pinion is pointed straight with the driveshaft and often vibrates if off by a degree. There's no way to set your pinion in line with the driveshaft with 1 degree side-to-side unless you're ok with having a 1 degree thrust angle.
