want to use part of original soft top hardware for bikini top so it can be flipped back so I dont have to reinsert plastic strip into channel . that would be a pain. I talking about using attached header that came with original soft top. using those small screws that attached fabric to attach new bikini top fabric that would have to be trimmed and then back attached to maybe the first bow with straps or velcro. Does that help?Not sure what’s your trying to do exactly? Try explaining it a bit better and you will get more help!
has anyone tried thisDo you mean to fit the original header channel? If so there is not enough material to cover the header where it would need to be screwed on.
any thing to get around having to remove plastic strip from channel and reinsert it every time you want sun or view of the skyhas anyone tried this
I would suggest getting another soft top and just running it without windows and trimming away any excess material. That would be much easier.want to use part of original soft top hardware for bikini top so it can be flipped back so I dont have to reinsert plastic strip into channel . that would be a pain. I talking about using attached header that came with original soft top. using those small screws that attached fabric to attach new bikini top fabric that would have to be trimmed and then back attached to maybe the first bow with straps or velcro. Does that help?
yes it would. may check about purchasing used full top for this. Thanks. want to do this on the cheap. Spent alot of money on spice upper door slider windows and wind jammerI would suggest getting another soft top and just running it without windows and trimming away any excess material. That would be much easier.
Just get an aftermarket header,they are cheapyes it would. may check about purchasing used full top for this. Thanks. want to do this on the cheap. Spent alot of money on spice upper door slider windows and wind jammer
not intending it to cover all the way back, just to the first fold back bowhas anyone tried this
do you mean not enough material to fit width of header?Do you mean to fit the original header channel? If so there is not enough material to cover the header where it would need to be screwed on.
Better grammar would help.want to use part of original soft top hardware for bikini top so it can be flipped back so I dont have to reinsert plastic strip into channel . that would be a pain. I talking about using attached header that came with original soft top. using those small screws that attached fabric to attach new bikini top fabric that would have to be trimmed and then back attached to maybe the first bow with straps or velcro. Does that help?
