Rush,
FWIW, If the fan only blows on high, and not on 1,2 or 3, the resistor is the issue most every time. I know that was not your issue, but stay with me now. If the fan does not blow at all, the fan motor itself is toast, the resistor is also toast, a fuse blew or a wire disconnected somewhere. If you disconnect the fan motor from the electrical connector, and you add power and ground to the two connectors with jumper wires, does the fan motor spin like crazy? If not, the motor is most likely toast. It might only work enough to spin on low. If it spins super fast,that means it works. Is it POSSIBLE then, that the new resistor is not working properly? Perhaps the speed switch is the culprit instead. Make sure the blower motor works when directly wired first tho, otherwise you can chase your tail for a long time.
