Will LED's work in these ok or should I stay with the Halogen bulbs?
Hella 002395801 7" Round E-Code (ECE) H4 Conversion Headlight Kit | Quadratec
Same here on both accounts. Great setup.I run BeamTech LEDs in mine.
Do you or John happen to know which beamtech? There seems to be a few H4 9003's.I run BeamTech LEDs in mine.
I got theseDo you or John happen to know which beamtech? There seems to be a few H4 9003's.
No need for new flasher?I got these
BEAMTECH H4 LED Bulb, 50W 6500K 8000Lumens Extremely Brigh (9003 Hi/Lo) CSP Chips Conversion Kit Fanless All In One Plug N Play Low Fog Light https://www.amazon.com/dp/B06XHD78DQ/?tag=wranglerorg-20
Says they don’t fit, but that’s because they fit the H4 housings which aren’t factory but look factory
I installed a Novita LM470 relay because my tail lights are LED. Shouldn’t need it for headlights only.No need for new flasher?
Same.I got these
Yea, most the LED headlites aren't the best looking - but to my mind the largest advantage of the E-code Hellas is that they're made out of GLASS. These plastic headlites only last a few years here in Florida - dumbest idea ever. After touchscreens at least.I will further comment that I'm seriously considering going back to this setup from Trucklites because of the way the look when off fwiw.
The cheap solid state circuitry in the Chinese LEDs is prone to RF problems which is exactly why I stay with the H4 halogen style bulbs....Many hams report RF interference issues that can be traced to aftermarket LED's. I know hams who own jeeps, Xterras and Toyota 4Runners/FJ's who have all been forced to deal with this issue with both ham and CB and who either completely changed their antenna location and cable routing or ditched the aftermarket LED's altogether.
That's why I avoid them.
I use Philips Xtreme Vision +130 60/55w H4 halogen bulbs and recommend them to others. No RF interference, no harsh glare for yourself or other drivers, none of that bluish tint favored by the ricer crowd. If you can't see with these you are either going way too fast or have a vision problem that should be addressed with something other than brighter light bulbs.
