I’ve been working to install H&R springs with a ¾” spacer and Bilstein 5100s the past couple days following this wonderful thread https://wranglertjforum.com/threads/stock-spring-swap-walk-thru-with-pics.12655/#post-202026
I was having trouble getting the springs to slip in with the spacers so I dropped the lower suspension arms. After putting everything back together I noticed the axle out of alignment. I dropped everything again and realigned. After the second time it was better but still rotatated out of alignment.
The left side is in place but the right side is out.
Will the right side slip back into place as I put everything back together or do I need to do something else? Bolts are just there to hold in place they have not been tightened down.
