I’m not familiar with the dual durometer bushings. Is this an example?
https://www.synergymfg.com/synergy-dual-durometer-bushing-ddb-series.html
So it seems I have the following choices
- Replace with Rough Country parts. Probably ~ $500 just for the rod ends and probably closer to $650 if I replace the clevites. After all that I’m back in the same place in 10 - 30K miles and I still have entry level arms
- keep the arms but replace rod ends with johnny joints and crevices with dual durometers. Looks like $200 for the dual durometers, and ~$500 for the johnny joints.
- Drop the coin on metal cloak or Savvy
- I don’t think stock arms are an option unless I go to a smaller lift/tires based on what I’ve read elsewhere on the forum.
These are on a ‘04 LJ with an unknown lift, I’m guessing 4”. It has 35x12.50x18 with nitto mud tires which I’m replacing with a set of 285x70x17s from a JK for now. Driving is majority on street with the intent to go off-roading more as I get it fixed up, but more trail running, not rock crawling. More getting out there to see things and places off the pavement rather than can I get through a crazy trail. I had it at hollister a couple of weeks ago and it was struggling on obstacles that my ’99 TJ with a 3 inch lift made it over easily.
So clearly option #2 is better than #1 since the cost seems to be roughly the same. Now I need to decide the trade off of rebuilding inferior arms or just buying new better arms. For the milder wheeling I’m doing am I going to notice much difference having the dual durometer bushings on the end vs a JJ/metalcloak?
