So right now I have a 3” lift on the Lj and I am running Rancho 9000 shocks. The front of the Jeep is about 3/4-1” lower than the front, some is the rake and some is from the arb bumper and winch. I want to level out the Jeep and I was going to just use a 3/4 in spacer in the front. My issue is right now the shock I have has 14.6 compressed length, 23.09 extended and 8.45 travel. The bump stops are properly set, the Jeep at ride height has 4 1/4” of the shock shaft exposed so the baias is about as close to 50/50 I could get. The thing rides and handles great. If I add 3/4 in of spacer I obviously will lose some down travel, but is it worth it to actually replace the shock? The next size shock has the following length 16.1 compressed, 25.9 extended, 9.8 travel.
