The passenger lower bolt will not break free. I can’t hold the star bolt head tight enough to break the nut free. I tried a hammer impact tool, that just spun it like I was doing by hand. I lubed it, maybe that will help. Do you think I would have any success with an electric impact wrench? My buddy has one I can borrow. I really don’t want to cut it off if I can avoid it. Anything I do, cutting it off or whatever, I will have to go buy the tools. I only have wrenches and such. I could take it and have it installed but it seemed such an easy job. Seemed.
Another question. It states 10 degrees on the sway bar with the new hardware. Doesn’t state which way. I’m almost positive it ramps up from front to rear. Is that right?
I lifted the Jeep with the sway bar disconnected, with the tires just clearing the ground the brake lines weren’t strained. Is there something I’m overlooking in that area as far as how I’m checking it?
As always thank you for your expertise.
