OK - got another long winded question -
My '03 TJ with automatic and Dana 35/3.73 rear axle whines. PO or O's didn't take care of her - when I got her the lube was chocolate milk.
So - what to do, what to do. I'm not a rock climber so plan to stay with 3.73. 155k miles. I'm not into rebuilding, figure I can find one for a lot less hassle. 42RLE tranny and ABS.
So - questions are -
1. Do I stay with Dana 35 or put a Dana 44 in?
2. If Dana 44, I believe I have to shorten the driveshaft, or did Jeep they make one?
3. Are all Dana 44's disc or do they make drum?
4. Did they build a Dana 35 with disc brakes? If so, could I assume that would that be an indicator of axle build date (mine is drum - it's an '03)?
5. I realize switching to disc's I will need to replace the balancing valve. Where is that located?
6. What about ABS rear sensors - is the wiring there?
7. What issues will I have with the E-brake - do I need to be sure to get specific linkage parts with whatever axle I find?
Thanks in advance for any advice you may have to Offer!
