High beam light
Aidenk
United states
Hello all on my dash my high beam light is on all the time even when my high beams are off. The high beams function fine. I recently installed a new switch panel. Any suggestions on what this problem may be?
Thanks
Thanks
It looks like the indicator light should only get power when the high beams are on.
You might try pulling the fog light relay. Maybe power is backfeeding through it.
Not sure what you mean by new switch panel?
In your avatar it appears you have Off Road lights; do you have an aftermarket switch panel for those lights?
What kind of new switch panel did you install ?
Did you wire into the factory fog light wiring ?
You need to further explain so that forum members can assist you in troubleshooting.
I recently had the same issue.
Checking connections between the harness and headlights, I noticed they were pretty well caked with dirt and grime. I unplugged the harnesses, cleaned everything up and blew them out with compressed air, then applied a coat of dialectic grease to both the male side on the headlights and female side on the harness before plugging them back together.
Everything's worked perfectly since.
