Probably going to do my first oil change in the next few 100 miles. Not sure if I should go with a high mileage oil or a full synthetic. My TJ has 89,000 miles on it btw.
You da man. That's it!Here it is.....What type of oil do you use?
https://r.tapatalk.com/shareLink?share_fid=1075363&share_tid=2947&url=https://wranglertjforum.com/index.php?threads/What-type-of-oil-do-you-use?.2947/&share_type=t
X2, just change the oil and filter and you'll be fine no matter what oil you use. I don't believe in 3,000 mile intervals though, that short of an interval for normal driving didn't come along until Jiffyworld started pushing that interval for obvious reasons. I stick with every 5k miles and conventional motor oils which have worked well for me the last 50+ years, never an engine problem. Though if I lived where it got uber cold during the winter like upstate NY, Minnesota, Alaska, etc. I'd definitely pay extra to run a synthetic during the winter.
Exactly. And if every 3k miles is better than every 5k miles, maybe every 2k miles is better yet.I agree with this. I change my oil out every 5-6k miles and have for the past 10 years.
I think the 3k mile oil change interval is nothing but a myth. However, if you want to change it out every 3k miles, then by all means, do it. I'm simply saying that in my mind, there's no need to.
I'm not a fan of synthetics except in extreme cold conditions but modern synthetics won't cause leaks like older synthetics earned a reputation for. The manufacturers started adding an additive to synthetics to help insure the seals stay swelled up and leak-free. RMS leaks are common enough that I'm betting it wasn't caused by having switched to a synthetic.I am a big fan of syn oils and have run it from the beginning in two of my vehicles; my Silverado has 150k and Honda Fit has 335K without issue. I bought my 05 SE with 101K and put in syn when I did a full maintenance routine on it. Within a few weeks I had a rear main leak that wasn't there when I bought it. I had read about changing to syn in older engines causing/accelerating leaks. Maybe purely coincidence, maybe not, but I switched back to conventional a few days ago so we'll see what happens.
