I've been waiting for 20 years of running TJs for someone to talk first-hand about having personally needed to replace a failed camshaft or lifters from running standard engine oils that all contain less zinc than used to be in oils.
The fact of the matter is the zinc content isn't a factor with a stock low-compression (glorified tractor engines
engine with standard valve springs. If I was running a high-performance engine with an aftermarket cam with stiffer valve springs I'd definitely want more zinc. But for a stock engine, it's a non-issue. In the multiple (!!) Jeep forums and news groups I've frequented since 1996, I've yet to read of a single Jeep owner with a stock 4.0 engine that had a camshaft failure. It doesn't happen. Which means the zinc issue is a greatly exaggerated (non) issue for us stock engine owners.
I'd love for someone to provide a link to a single failed standard low-compression Jeep 4.0L camshaft proven to have been caused by using a modern multi-weight oil.
Not to mention my daily-driver high-compression BMW and Lexus engines don't have camshaft problems with standard motor oils either.
